Thanks.
I couldn't find a reference in AC 43.13-1B that said what the X meant.
7-36. IDENTIFICATION.
Aircraft bolts may be identified by code markings on the bolt heads. These markings generally denote the material of which the bolt is made, whether the bolt is a standard AN-type or a special-purpose bolt, and sometimes include the manufacturer.
a. AN standard steel bolts are marked with either a raised dash or asterisk, corrosion resistant steel is marked by a single dash, and AN aluminum-alloy bolts are marked with two
raised dashes.
