Yesterday I was preparing to cut the canopy on a 9A when an old friend "IA" stopped by to visit and asked what I was going to cut the canopy with. Like everyone else, the die grinder and a cutoff disc. He said he had something better and returned in the morning with an orthopedic "CAST CUTTER". That is correct, doctors cut the cast off a broken bone etc.
The old "IA" has been cutting plexi/Lexan for 40 years with it with no problem.
I tried it and was amazed......no dust at all....no need for a mask.....no hot chips....no melting plastic......thin circular blade appears to be rotating but it's not, it's oscillating.....very fine control....does not want to climb if going in the wrong direction........ you can put it on your hand and it will not cut you.....and it's quiet, no compressor or high speed angle grinder noise.
First cut was to "score" a groove as a guide, second pass was right through like butter.
Find your doctor friend and see if he will let go of one. You'll never give it up.
Works good and lasts a long time......Heliojoe.
