rjcthree
I swear, I think my wing kit - specifically my spars, were made after a liquid lunch was served to the hole-punch operator.
11th rib outboard, the predrilled holes for the spar and waffle plate are horizontally off by 1mm! Clear as day, for anyone who cared to look. So, which is correct? Waffle plate or spar? I took a few measurements, decided the spar was ok, redrilled (so the waffle plate holes are oval at rib 11) and moved on, figuring an extra half-length will be required to fill the hole. No biggie.
If only.
Wing jacked up, level, square spar, not twisted, upper outboard wing skin holes drift out of alignment while moving inboard, in just about the same place and amount the spar/rib holes are out. Great!
Has anybody else had these kind of issues?
My plan right now is to do my best to get this skin aligned, I'm making an extra TE spar jack, hoping I can juggle everything and make this my mistake, but I'm not hopeful.
If that doesn't work, I'm going to get permission to drill and dimple these as -4's, which is the only way I can see not having half-moons of unsupported material, etc.
I bet the fitting of the outboard LE is going to be a complete fiasco too.
RIck 90432 - staring at wings
![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
If only.
