BLUEWAVERV7
I'm New Here
Has anyone used a 3 bladed aluminum constant speed prop off a arrow 200HP on a RV7A with a Lycoming 390 and how was the performance?
The danger of using a composite prop on an RV7 is that you can end up with an aft CG problem and have seriously limited baggage capacity.
Except that an IO-390 is heavy enough to cancel that out.
