RV-4
Hello All
I have a friend with an RV-6 with an Ameri-King Encoder (ACK-350)installed that is reading 200 feet high ...
Anyone knows how to adjust the Alt pots( Hi or Low ) and how much of a correction to amply to get the altitude down 200???
Bruno
I recommend you don't try it without the proper equipment to perform the full calibration which is a P-S test box and encoder test box.
In the USA an owner making that adjustment would be contrary to the CFR's, I imagine it's the same in CA.
Encoder
Thanks for the info Walt, I'll pass it along to my friend
Greg, Yes we're aware of the Ameri-King saga and replacing the encoder is an option my friend is looking atif he can't make to work properly.
Thank you Gentlemen
Bruno
