In my opinion, if there is going to be only one mod/upgrade, it would be this.Thinking of switching out from Van's alternator to a B and C alternator. Two questions:
Is this a recommended upgrade?
If so what B and C alternator part number did you order and what options?
I am getting and IO-390-EXP engine.
If I am reading B&C website should be the LX60 Boss mount single grove. Now I just need to figure out which belt 7360 or 7365?
Go the 7360 belt, probably more common for RV type planes. If you need slightly shorter or longer belt, you can whip down to your local auto parts store & ask for what you need. Same thing as your regular auto V type belts.
