scottjohnsontampa
I'm New Here
I am replacing my vacuum AI & DG with Garmin g5's so I can rip out my vacuum system. There are two alternators by B&C that fit the vacuum pump drive. They are 1.) B&C BC410-H SD ALTERNATOR 20-30 AMP
2.) B&C BC462-H ALTERNATOR 35-45 amps. Does anyone know if the larger alternator that produces 35-45 amps will fit on a lycoming 0-360 vacuum pump drive mounted on an RV-6A? Also, are there any other options for a vacuum pump drive alternator I should consider? I do have a primary alternator from Vans, but desire to have a second one after I have pulled out the vacuum system.
