Hi all-
Was flying back from the TERRIFIC weekend put on by Larry Vetterman in Hot Springs SD when I noticed that my alternator out warning light started flickering. It would never come on and stay on except a few times for a split second. Mostly flickering. I watched the voltage indicator when the flickering occured and there was no change but when the light actually came on for a second the voltage would drop from the usual 14.3 v to maybe 14.2, 14.1, 14.0 but never below that. There were periods with no light flickering and I watched the voltage indicator for the entire trip and it never realled dropped for any period of time from the usual 14.3v.
I know alternator/electrical issues can be complex but what I am looking for is some guidance in how to approach this problem. I have the Plane Power 60Amp alternator AL 12-E160/B model which has an internal regulator.
I plan to remove the cowl and do the usual external inspection and will also crawl under the panel and check the wire from the warning lamp light however since I have seen a slight voltage drop that coincides with those times when the lamp stays on for a split second I suspect that this is NOT a warning light issue.
If the electrical gurus in the audience or anyone else for that matter would care to provide a bit of insight it would be much appreciated!
Thanks all.
Peter K
9A-230 hrs
Thanks all.
Peter K
9A-230 hrs
