rockitdoc Well Known Member Sponsor Nov 18, 2021 #1 Will these be necessary as separate panel warning lights if I have Dynon SV1000 EFIS's? I have looked all over Dynon's site and forum and cannot find the answer.
Carl Froehlich Well Known Member Nov 18, 2021 #2 Assuming you are also using the associated SkyView EMS, no. Carl
rockitdoc Well Known Member Sponsor Nov 18, 2021 #3 Carl Froehlich said: Assuming you are also using the associated SkyView EMS, no. Carl Click to expand... So, the SV EMS has a provision for warning of battery and alternator failure?
Carl Froehlich Well Known Member Nov 18, 2021 #4 Yes, by setting the low voltage alarm set point. You will get both a visual and audio alarm. Carl
rockitdoc Well Known Member Sponsor Nov 18, 2021 #5 Carl Froehlich said: Yes, by setting the low voltage alarm set point. You will get both a visual and audio alarm. Carl Click to expand... Thanks, as always, Carl!
