Do any of you know how many HP an alternator robs from a 180HP engine when the charging rate is 50 amps? Thanks, Larry
Are you considering V-belt power transmission loss? I recall reading somewhere years ago this was about 10-15%.I should have looked here first but got this answer from Google. Might be interesting for someone so I will leave it here
I found this formula to calculate how much hp is required to run your alternator.
amps x volts = watts
745.7 watts = 1 hp
hp x 15% = hp loss
hp +hp loss = total hp used
example
55 amp x 14.9v = 819.5 watts
819.5 watts / 745.7 = 1.098 hp
1.098 hp x 15% = 1.26 hp
