DCBrown198
Active Member
Patron
Is it bad form to run the 18ga alternator field wire (external regulator alternator) and the alternator's 6ga output wire in proximity to each other as they pass alongside the engine? Any hall effect interference, or anything that might make this a bad practice?
Thanks!
David
I used the big wire on my RV-10 to support the field wire and tied it with wire wax string. No issues at all. Doing the same on the -9A.
