A bracket would be hard to bend up from one piece of flat stock and get the dimensions right. I have made them from two pieces of 1/4" mild steel angle. Drill them for the long mount bolt then cut the other legs of the angle to get the correct length and weld them together.
Not sure how I feel about welding two angles together given the environment and importance of this thing.
I'm wondering the same thing with my non-standard alt. Figured I could bend one myself with some heat. Not sure how I feel about welding two angles together given the environment and importance of this thing.
Yeah, I have thought the same about engine-mount tubes.
