Juicegoose
Alternatives in pipe for shop air distribution.
Alright so I've been on a compressor/air line kick. Basically i'm trying to get everything setup so when I get into my new garage I can install all the wiring/air lines needed for the build. Along the same lines has been alot of research especially into the use of different types of piping possible for use in a shop air system. Here are the choices I've found. As a side note I recently came across the rapidair system www.rapidairproducts.com they seem to have a pretty cool little idea going. I've been researching their website. DISCLAIMER: I am in no way associated with the company stated just a builder looking to spread the knowledge that he's spent hours researching. Let me know what you guys use So that the other guys can have a better idea of whats being used.
1. Standard ole compressor hose-
PLUS
- Inexpensive
- Portable
- Can handle air pressure needed for our uses (150-175psi max.. and thats pushing it!)
MINUS
- tripping hazard
- material used on some styles can breakdown over time and not be good with contaminates.
2. Black pipe -
PLUS
- Can handle any air pressure you through at it
- very strong and durable exterior
- fittings and pipe easily available
- Better heat transfer then PVC or hoses
MINUS
- Very labor intensive to install
- Water will rust out pipe from inside(eventually)
- scaling can occur over time(scaling in black pipe is the tendency of the coating to start to flake off)
- specialized tools required for install(pipe threader, monkey wrenches)
- Heat transfer can induce pipe sweating which in turn can cause slight water damage depending on climate.
3. Copper piping -
PLUS
- Won't rust or corrode
- Fitting and pipe easily available (Note: insure proper thickness is bought)
- better heat transfer then PVC or tubing
MINUS
- Labor intensive to install
- Not has durable as blackpipe
- Specialized tools required for install (pipe bender, cutter, solder, torch, knowledge of how to solder copper pipe)
4. PVC -
- Inexpensive
- Fittings and pipe easily available
- easily repaired or modified
MINUS
- Not rated or advised for compressed air
- degrades over time
- pipe easily cracked or broken
5. RapidAir flexible air lines
- Inexpensive
- easy to install
- easily adapted to larger pipe(blackpipe or there version of pipe airnet)
- easily removable
- No special tools required
MINUS
- Fittings seem to be bulky
- Availablity not as easy as others
- Max usuable pressure they recommend 150psi
- flexible pipe can be seen as not as a neat and tiddy install
PLUS
- Inexpensive
- Portable
MINUS
- tripping hazard
2. Black pipe -
PLUS
MINUS
3. Copper piping -
PLUS
MINUS
4. PVC -
- Inexpensive
MINUS
- Inexpensive
- easy to install
- easily removable
MINUS
