I'm installing an engine monitor that uses a small 1/8 NPT oil temp sensor. I don't want to remove my current oil temp probe on the oil filter adapter to install this sensor. Is there another location on a Lycoming AEIO-320 that I can use for this sensor. There is a 1/8 NPT hole that is plugged on the upper left side of the accessory case that appears to be in an oil passage. Would this work? How about a tee in one of the oil cooler lines? Should it go on the cooler inlet or outlet? Thanks.
