BruceMe
I have an IO-320 (note the 'I'). It's got the hidious backwards mixture cabling which interferes with the standard FAB.
I'm thinking about running scat from what is normally the carb-heat-air intake above the plenum directly to the intake. VFR Direct. I have three filteration options:
1 - No filter
2 - A cone filter in the plenum at the intake
3 - Remote filter box.
Any thoughts?
The air up there...
Bruce, Didn't know if you've seen the picture of my Ram Air setup in my -4 in the fuselage progress thread. Pretty easy to fabricate from .040. Mine is Ram inflight, pull lever, close flap, filtered on the ground. Works great...here is the picture again...
RR
my.php
[/URL][/IMG]
Be careful using Scat tubing for induction. There has been at least 2 accidents and 1 fatallity caused by Scat tubing collasping. Rare, but it has happened.
