macrafic
I see a lot of info on priming the insides of the push tubes. How about alodining? The Alodine 1201 instructions indicate that the alodine can be combined in a 1/3 - 2/3 combination with water and used as an immersion. I'm thinking that I would clean out the push tube nicely, cap an end, fill a bit over half of the tube with the alodine solution, then cap the remaining end.. Let the tube stand on end for 5 minutes, turn it upside down to get the other side, then drain and rinse.
Anybody see and disadvantages to this vs priming?
