I figure if it's good enough for the US Air Force, it's good enough for me.
I think you better ask the guys using it in the airforce and not prekote. The airforce is not getting good results
Richard,
I'm with Mark here. This thread has popped up several times in the past. Several years ago this question was asked on the Matronics RV list. I contacted fellow RV-8A builder Jerry Esquenazi about it. At the time, Jerry was a flight instructer at Randolf Airforce Base. He checked with the crew chiefs. They HATE the stuff. They only use it because the EPA is forcing the military to try and fine more environmentally friendly chemicals.
Prekote is hyping the Airforce use of the product. That doesn't mean that the Airforce thinks it's as good as chromate conversion products like Alodine or Iridite.
The crew chiefs reported that:
Prekote requires MORE not less prep work.
Primer adhesion with Prekote is not as good as with chromates (ie Alodine & Iridite)
Prekote offers NO corrosion protection.
They had several aircraft which exhibited peeling paint after several months using Prekote. I should note that this may simply be, because the techs were unfamiliar with the product at the time.
Bear this in mind. All the scarely language in the various MSDS's is based on you being exposed to the stuff 40 hours a week for multiple years. By using latex gloves and a modecum of care, you can Alodine every part on your airframe without getting the stuff on you.
Charlie Kuss
PS If you desire, I can look to see if I have Jerry's original reply regarding Prekote.
