nilberg
There are a couple of post about the benefits of the almost RV-14 modification.
I started this thread to figure out the how-to rather than discussing why/why not.
So here is goes....
I am in the process where I have to commit, that is cutting out the F-705. Most of the descriptions I have found (incl. the PDF on antisplataero.com) is for either RV-7/9 slider or RV-6 tip up.
I want to get to a solution that keeps the beefy angle and also uses the caps in the kit to not comprise the strength also give it s finished look.
Here is my starting point:
wpOwX1uvDgCs9V_E0Vrb18ffceozDbBTrG3OezH7xITm5nWFEMR0yupfQUfvEpSfgY6nAnEevncQsYwSA-vUGoGMgfn8vPVFjlH02kOn_ADACI4HLSinTIJRwqRlCIreg1lC7BZk8LpXeRgX9VTA-c_vJRHjPJWpjKjhMJXU2eNDqiYmcgAq_o46I5CRFB4TaImPfjLv0B4MpXb5xrQklStCEsVd_lX_wLGgpHQeMkLfe74qAxcaJiBWh-E4yxZ9bEcAwd1W3eaigAKe6r5XaH0QdD-p7Rgx2_Ra1wYF17ecHnqVPoP8vB-h8us1xkkeK3ZuTkLg1Kz8Sj9nSBw_qxa3Ze518yLRAIcTalPJ-naMh3yIdRhxbtism1RfQphL9pcZVZp_Z15KepbYSxk8AibwenAOjkctyoOlkr000ZK5Dp3m0bvYGOd99ntTC3hswLg6qc_5JPbeX4nSAXhBhnaS0roEZ8MAz3nDz5IBwMjPCqn-bMQoTbqj5xSVOeBaIvRZL2YhJbi6skoqOEmq8m_BgdOSWD3ftYnOEGD_ZltNFIwBB0v9viC3WhD_nurFvAgrjnN-z4ZwcfaQUgkSCtI8qwUkXgK9=w600-h800-no
I was trying to imaging how the new F-705 aka "ASA-705" will interfere with the beefy F-705B:
mh3x0ZFxvxMz3E4v3D6fGhthmannMEAaRuw-3entFaSS8NCbhtUkAiddExGStYgAtnkXFmicR5vuB-x9Q5E8TqGYW-YDSnF_xSBXPEYbESO88bfyA07rOSJqkc6Uk7FVD2f9ifGItYGMjnczhx2-mRr-mfKMkc2a4a6Emi1gaU4omZC5mShF88XZAfJlOKh3gORpvnzq8kQpDm12rTK-Wo9qJvAV43eWHFc0Ilo_ZM07pkVc0dxOSy6drSaRob22rV4z13jJCnOZjNBU_goSquyzSp0GBj1Jh2VX5qGQ0WZfaaOSkhp7U8ctidKBWmaft6UUwO_4GbrRvObSeuCG1cpOyM719YuwRcFdON7pP5xQ4FywaxXPc1eZV6DzAbQZ0_OgZpuD0JfgG2KpcKPyAStmw4iOasZ_U0KH8fnX5omlZqtBNrm9podqwg0KYlksK88WuW1iMhcvYx5awelyF24VrRASOp-pGp_zmzM1FYXidff6Vn-qN5DHG7TkhmPwJVxfYsOuVO2rkgNsU8Xv2wiQziumWsKJ-KGip1OcziurWxZHHPt9czLiyi88kZt_CC70y_3siIOPHii49lIr0X7Z5gogp4qb=w600-h800-no
It could be I need to trim the new 705 a little in order to keep the F-705G.
Or should I just fit it just being the F-705G ?
For everything else the PDF illustrates the install pretty good.
At this point I am looking for pictures of another RV-7/9 tipper almost RV-14 install.
Does anyone have pictures to share ?
I’m with Bjorn. Getting close to the point to commit the cut. Pics of the tip up and slider would be helpful.
