Hallo.
I'm flying since 2011 without issues.
Three weeks ago I moved my battery aft for CG reasons. Airplane is now a joy to land. I locally grounded the battery with a strap connected to the center aluminium angle and a couple of other wires (see my www.rv9.it site, flight! page - all bottom - for photos).
I had a couple of flights with no issues with the new configuration.
Today the first flight was OK. During lunch, a storm passed.
After switching on engine, the alternator field breaker popped. I tried to put it again in but popped one more time. So I did not touch it any more. No problem, I thaught. I have a 25' flight to do. Will go with battery only.
After a while, radios got stuck. I couldn't hear my partner and he couldn't hear me. Our friends told us later that everything we were saying was broadcasted since we had trigger on. But we hadn't. I believe once I pulled the radio PTT something happened and it remained stuck. Also we could hear some noise in the headsets even with radios and audio panel off. That is strange.
I tried to switch off the GMA audio panel, the GNS430W and the SL40 radios and again on. Nothing to do. All stuck again. Actually, when I first switched on the audio panel, the COM1 button blinked (that means PTT is engaged, I believe) and then when I also switched on radios, we could hear a lot of noise in the radio. So we shut them off again.
Just before landing, I tried to push the alternator field in and it came alive. I also tried again with radios, but the same issue occured.
Once on ground, I removed the seat floors and the cowl. All in order. I switched on battery master and avionic master, and radios worked properly.
I can't imagine what happened and if this can happen again. Next friday I will depart for Greece and it would be a shame if I will have to abort my trip.
My only thaught is the storm made wet some part under the cowl OR the avionic ground return via the airplane frame is not enough (I monitored battery bus voltage and it was 12.5-12.7; maybe a ground bottle-neck effect can't be detected from voltage...). I can't imagine other solutions.
Do you have any idea?
Thanks.
Camillo
Thanks.
Camillo
