Bryan Wood
Hello all,
I have a question about errors in the airspeed indicators for RV's. My 9A seems to indicate about 180mph true on my airspeed indicator regardless of power setting as I put in more throttle and rpm. I can watch the groundspeed increase as more power is set, but the airspeed indicator seems to settle in around 180mph true. It does however increase when the plane is nosed over and speed obviously increases from the previous readings.
Last weekend I flew beside my father-in-law for some in flight photos at 4500' and once again my airspeed showed 180/181mph, and his showed 188mph true.
However, our groundspeeds were the same.
His airpspeed has always seemed right and matches many airplanes he has flown with. He has owned his airplane for approx. 30 years and is sure his is close to right on.
Does anybody have any ideas? It seems like if there was a leak the indicator wouldn't increase when the plane was nosed over. I wouldn't worry about it but during decents I have brought it up to the yellow quite often, when actually I was probably closer to the red. Also, just knowing the real speed of the airplane should be a gimme.
I know it is kind of hard to complain when you confirm that your airplane is about 8mph faster than the guage shows, but now that I'm finished smiling about my new found speed I'd really like to see it everytime I fly.
Bryan Wood
Bryan Wood
