Dean Pichon
I'm trying to improve the connection between the lower cowl of my -4 and the airbox. The current configuration is basically per Van's plans and has a couple of shortcomings. First, there is only about 1" clearance between the airbox and the cowl. I believe this short gap allows cowl movement to transmit load to the airbox which ultimately causes cracking of the airbox mounting plate. Further, this limited clearance between airbox and cowl makes the removal of the lower cowl difficult. Finally, the wrapped fabric approach may leak some air and reduce, to some extent, the manifold pressure.
To improve this situation, I plan to cut back the airbox to increase the gap from 1" to 1-1/2" or 2". I would like to change the interface seal from silicone sheet rubber to SCAT tubing. Has anyone tried this? Has anyone else tried something different that they could recommend?
Thanks in advance for the help.
