dan carley
has anyone had a vibration in the air speed indicator and altimeter due to a vibration from the propeller. i have a metal sensenich prop on the rv. i've checked everything out no leakes, at a 160 mph needle is smooth around 2400 rpms, but over 170 mph 2500 rpms it will wiggle
any thoughts
dan carley
Good vibrations
Hey Dan,
There's an easy fix....
Quit looking at them! :)
V/R
Smokey
PS: If you haven't done a dynamic balancing on your prop, do it. Worth every penny. My advice, sell the Sensy and get a Catto...better performance, smoother, less weight and no RPM restriction.
