freegespeed
Active Member
I own a nice little 6A which I didn't build, so all the little mechanical detail stuff is undiscovered country to me. My latest issue is with my manual airleron trim slipping at certain positions. If I move the lever a full 90 degrees it stays put but at 45 degrees it slips back to the neutral position.I never need the full trim setting, so I try for the 30 to 45 degree lever positions and it just won't stick.
I think this should be a pretty easy fix but I thought I would try to get some guidence first. Any help would be appreciated.
