Surfdoc
Member
Getting ready to order the Fuselage kit. installed a Dynon autopilot roll servo in the wing. Do I still need the Vans aileron trim servo? Or manual trim? I am unsure if the Dynon servo will also "act" as a trim servo. Many Thanks in advance
The Dynon servo will not act to trim the aircraft. That said, if the aileron trim needed is light, the Dynon will fly the plane with the autopilot engaged.
I highly recommend aileron trim, manual trim for aileron is lighter, easier and works great.
