I'm finally getting close to finishing my slow-build wings, and thought that of the tasks that remain that I would go ahead and install the aileron trim motor assembly even though the plans are written such that they assume the wings are already installed on the fuselage. No problems with the kit and even crimping the tiny molex pins to the wires didn't present too much of a challenge, but once everything was done I found that trying to attach the springs to the swing arm through the access hatch (while the access hatch and trim assembly are trying to close the hole) is just about impossible. How have others completed this step? I'm thinking this is one of those times where you need to call your neighbor for another set of hands. I've attached pull strings; one leading inboard for the outboard spring, and one leading outboard for the inboard spring thinking that if I have my neighbor pull on the strings (springs) then I can attach the other end of the springs to the swing arm while he's pulling. Thoughts? Any other strategy for attaching the springs?
