If you mount your magnetometer in left wing as per plans, better to mount trim in right wing. Also, the left harness is pretty full going through routing bushings. Not a problem routing through the right wing. Be careful about inverting the install.
anyone using the manual aileron trim kit? $46 vs $300 for the electric and seemingly easier install
