I've been playing around with my ailerons tonight, trying to figure some things out. The thing that's puzzling me now is that there is more upward travel allowed (before hitting the stops) than there is possible downward travel (before the bellcrank is completely vertical, and LE skin of aileron contacts trailing edge skin of wing). When the ailerons are linked, this means that one aileron will reach the limit of its downward travel (bellcrank fully extended) before the opposite aileron hits the stop. This means it will be impossible for an upgoing aileron to ever reach the control stop, and aileron travel will really only be limited by the bellcrank (which, when aligned vertically with the pushrod, has the aileron at the maximum downward deflection possible).
Have I misunderstood something? If the stops can't be reached when the ailerons are linked together, why are they even there?
