Freemasm
I'm building an F4 (Rocket lite) with a "standard" RV-4 wing. I've heard side discussions about the aileron skins being updated to a thicker gage. The skins I have are 016. I've seen an RV-8 drawing but it only references a pre-punched part/part number. No material dims.
What are my current risks as is?
Should I go ahead and plan on reskinning? If so, at what thickness?
One step forward. Two steps back. Story of my build life. Thx.
Updating Aileron Skin Thickness
I think you will find Van's very reluctant to make "special" skins other than what is called out in the plans. 30 years ago they would (I have a set), but now - not so much. I tried to get them to make me a set of .020" aileron skins for an RV3 I am currently building - answer was "We don't do that anymore."
Good Luck - maybe an "aftermarket" manufacturer?
HFS
HR II S/N 002
Thanks to all
I suppose the 016s are guaranteed to crack?
Can probably form one myself if:
I can borrow the long brake at the FBO
I get enough 020 to ruin a couple first
Any other info, please forward along. Thx.
RV8 quick build ailerons
Just buy a set of RV8 quick build ailerons ....they come fully assembled and are same dimensions as RV4 ...
This. Or -8 parts and build em up. I went from .016 RV-4 Ailerons to .020 skinned -8 Ailerons because of skin compression at higher speeds. Yes it's real and yes it made it fly like a new airplane.
Dilemma
Thanks to all. Here is what I'm afraid of.
These are all slow build construction. If I purchase -8 parts (pre-punched), worry the ailerons will then be out of plane with the flaps. Or maybe the trailing edges won't align, etc.
I'd like to get a ride in this #$%@! thing before I die.
Not a worry
Ailerons and flaps will be fine as you would also need to buy some of the mounting brackets ( part number escapes me ) ...they come predrilled and blank ...so if the predrilled isn't bang on ....you can drill your own . Takes a bit of work and but covered in several posts on VAF
Even when you build the pre-punched RVs, there is no guarantee the flap and aileron edges are aligned perfectly.
