Michael Burbidge
The instructions for the smaller aileron push rod say that instead of using two rivets to connect each rod end to the rod you can weld the rod ends to the rod. So I thought that sounded easier than trying to drill a straight hole through steel with such a small radius.
So I took the rods to my local welding shop and had the ends welded to the rod. But now I'm wondering how I know if the weld is good. With rivets you can just look at them and see that they are still secure. But with a weld you can't. This may always be in the back of my mind because this is such a critical connection.
Did anyone else have these welded and have similar thoughts?
