I'm installing the aileron gap fairings and running into an issue with the top skin. The gap fairing pulls the top skin down slightly, but where the fairing stops there's about 10 inches of top skin that's not pulled down. I've seen it posted elsewhere but haven't found a resolution beyond bending the rear spar, which seems excessive. Should I just gently "bend" the 10 inches by hand to match the rest of the skin contour? Also, should I continue the bend along the top skin at the flap, or just let it remain as is?
