I want to install the aileron controls in the wing before i rivet the bottom skins. do the parts, bell crank,push rods come in the kit? or do I have to make them?
What kit? That asked, the material is in the kits. You may have to cut to size, prime, install rod end bearings, etc. I don’t recall that assembly in a completed wing was particularly hard.
You could assemble and trial install & rig the controls prior to closing the wings. But the bottom skin riveting process would be MUCH easier to do if the linkage was temporarily removed. Easy to reinstall & rig this stuff after the wing is closed.
