The outboard aileron brackets on my RV8QB do not fall perpendicular to the aft spar, as shown in the plans. Rather, they "cant" slightly inward by about 3-5 degrees. This creates two problems: Fiirst, when applying the mounting bolt through the bracket bearing, there is some interference between the washer nearest to the bearing on the outboard side, and the lower radius of the outer bracket surface. The second problem is with the inboard bracket: The aluminum spacer is now longer than what the plan specifies, and I've had to alter the washer thicknesses and number to accommodate the aileron bracket without squeezing or spreading it. There is also some interplay between the pushrod that comes through the aft spar and the inner curvature of the spar orifice, indicating a need to widen it by about 1/4 inch. Van's tells me I can use a smaller washer on the outboard bracket to eliminate the interference, but I would greatly appreciate the input of those who may have had this situation. Thank you very much.
Tom Navar
RV-8QB
C-180
Pitts S2A
Tom Navar
RV-8QB
C-180
Pitts S2A
