Stewbronco
Hi all ... new to this . Many thanks in advance. Stew
Flys fine ....and has for 618 hours and I get the concept but worry about weight behind hinge line and potential for flutter .
Many thanks to all ! So I think if I read that correctly is to statically " balance the aileron " much like you would an elevator? Makes good sense Cheers. Stew
I personally wouldn't be concerned with adding the weight along the entire span. You will be adding a small percentage of the overall amount. Assuring that it stays put is much more important than distributing it evenly. That is why I suggested standing it on end while it cured.
