lsissom
Active Member
Tip Up Canopy question
So... after successfully separating the front from the rear canopy, I have been trimming and re-trimming the leading edge of the front canopy exclusively in an attempt to make it lower, thus allowing the lower portions of the aft edge to line up with the marks on center of the roll bar. (the canopy was quite a bit higher than the roll bar before the big cut...after the big cut , the aft edge setttled lower , but now doesnt line up)
This had been a painfully slow process and I'm starting to question my methodology.
I'm I correct in NOT trimming the rear edge of the front canopy after making the big cut? Other than just smoothing the edges, I haven't touched it.
