I'm currently installing the aft fuselage wire harness (WH-00057) per the instructions in section 10-25. There isn't a lot of space for the wires as they pass between the bulkheads and J-stiffener and it seems like any movement could cause damage to the wires over time. I'm considering wrapping the bundle with heat shrink in those areas but wondering if there is a better way.
Also, wondering about those that have flying -14's have any second thoughts about how the harness was routed. Having to climb in the tail to pull another wire in the future seems challenging with all the tie-wraps. Or, is this a "stick to the plans" because it's a non-issue? I figure now is the time to consider it before I rivet all the skins on.
