I was talking with fellow builder Bill about mounting the empenage the other day and he said that there was somewhere (he couldn't remember exactly where) you had to be careful not to drill too close to the angle in the longeron. Well, I think I found it...
I drilled the the AN3 bolt holes for the aft elevator stop too close and can't get a washer or nut on the bolt. I am thinking about re-making (for the 4th time) the aft elevator stop to give me more space forward along the longeron to drill another pair of bolt holes. Instead of being about 7/16" from the aft end of the elevator stop the bolts will likely be about 14/16" (7/8") from the aft end of the elevator stop. Will this be a problem? This angle is also connected to the vertical stab. So, I am a little concerned with the bolts being farther away than specified. I have even considered also getting a couple of -6 CherryMax rivets and putting them in the 3/16" holes that were drilled too close. Am I over-analyzing???
