I have a PS8000B audio panel installed and now installing an AFS AOA. I would like to hook up the AOA audio so that I get the aural warnings. I am wondering about the easiest and best method.
The 8000 came with a audio input which I have already wired for my IPOD and works works nicely. The AOA instructions say that you can wire it to one of the headset outputs at the plug end. It looks like I could run a shielded wire(?) set (hi,lo, grd) to the headset plug or imput it into the IPOD jack which cuts out during transmissions/receives.
They say in the instructions:
"standard cable is provided and pre-wired at the 25 pin
Dsub end. The other end of the harness is wild. Note
Appendix B that describes the Dsub25 pin connects to be
used in the following instructions. Ring out the wiring
harness now.
The harness is wired for a 560-ohm audio output that
allows you to match the output impedance of the AOA to
standard aircraft headphone, audio panel and intercom
audio devices.
Direct wiring to non amplified standard 26-ohm cockpit
loud speaker will require the 26-ohm audio output and a
ground (audio low). This will require the addition of a
two conductor shielded cable not supplied."
I am assuming that I would use the 560 output no matter which direction I went.
Also, did anyone mount the Sprort LED indicators on the glareshield instead of the panel? Would like to see pictures if possible of the glareshield mount.
Comments or suggestions appreciated.
Thanks Bill S
7a finishing
harness now.
audio devices.
Thanks Bill S
7a finishing
