cojaken
Active Member
I recently had a bug block my pitot on short final and lost airspeed indication.
I landed successfully, but realized afterwards that the AOA might have helped me, if I had looked at it! I have the AOA ports on the wings, not on the pitot tube.
So here’s my question: with a blocked pitot, could I have flown by the AOA or is the airspeed part of the input to tha AOA algorithm?
If your AFS AoA is a standalone unit like mine, it has a connection to the pitot tube. From the manual, AoA is a function of the difference between pressure at the upper and lower AoA pressure ports *and* the difference between pitot and static pressure. So, if the pitot tube is blocked the AoA you see almost certainly isn't correct.
HTH
Dave
If you have the ports in the wings as you say, The AoA may be independent of airspeed. But I think only AFS or someone with knowledge of their system can reply with certainty.
I too thought it was independent, but Dave is correct. The manual says they are normalizing with dynamic pressure (q=Pitot pressure - Static pressure) when using the wing surface probes, so pitot and static are needed for the AOA solution.
Quote from the AFS AOA manual:
"The result of dividing the airfoil or probe differential pressure Pw by the pitot static differential pressure Pp is a coefficient of pressure (CP). There is a unique variation of CP with angle of attack."​
So if airspeed isn't looking good, don't rely on AOA indication with this setup.
Lenny
