I'm working vigorously this extended weekend with my A&P on a 5600 and associated components of a quick panel.
I might be overlooking something obvious in the AFS 5000 install manual, but I can't figure out the pinouts for the ADAHRS unit. It is the 9 pin Sub D connector, one end of which came with the connector installed.
And, once the connector is installed, does the cable run from the ADAHRS to one of the SV network jacks on the AFS ACM?
Lastly, both the Dynon radio and the AFS/Dynon autopilot have two SV network jacks? Do both (always) get connected, or need I just connect one to the network hub on the ACM?
Thanks for any help.
