SMRacer
Patron
I have an AFS 5600 EFIS and an underwing pitot/AOA sensor. Until recently I was receiving all the AOA aural tones associated with approach speeds. I then installed a PS Engineering PAR200B audio panel/remote transceiver, adding to my original Dynon Com. I removed the Dynon intercom. After the audio panel install I lost all of the aural tone approach speed beeping.
Anyone have this combination, or know what might be blanking out the AOA aural tones?
I don't have the same setup, but have a PS Engineering PM3000, and had to connect my Dynon and other audio outputs to one of the PM3000 Unswitched Audio Inputs. I don't know if your PAR200 has those. You might try calling PS Engineering; Mark Scheuer is in our local Knoxville EAA chapter and a good guy.
Did you connect the Audio wire from the AF-5600 to an unswitched input on the new PAR200 audio panel?
EFIS Pin 18 should connect to the PAR200 pin J1-31
Rob Hickman
N402RH RV-10
