Can someone with a 6/7/9 (not sure about other configs) and AFS setup (ECM/flap position settings) share their flap configuration settings or tell me is full down is zero or full up is zero (or close to it)?
I had one flap display showing fully deployed while the other showed fully up (PFD was correct). I was getting the flap overspeed warning, and don't think I can calibrate AoA because of it. Crummy weather Friday so I was able spend a few hours working on it.
AFS support is awesome and sent me an update in about 5 seconds, and I believe the S/W update, or just going through setup again fixed that issue. But I think I pulled a wire out of the molex on the flap position sensor while troubleshooting and lost the value from the fsensor.
Of course, mid troubleshooting I had to leave the plane to go see my little sisters college graduation who just finished her ChE degree (good reason to leave). For the next few days I am 3 hours from the plane.
Re-reading the AFS manual and I noticed that in their example Flaps full was a 0 setting and flaps up was 137, whereas mine were the opposite.
Would love to be working on it now, but at least would like to know if I just messed up on initial set up so I know where to start when I get back out there.
Thanks-
dan
Thanks-
dan
