Chippster1
Active Member
I am considering upgrading my AFS 4500 screens. Should I just stick to the AFS 5400, which is a drop in replacement for the 4500? Is it a big deal to place the 5600 which is only slightly bigger? Do I have to replace the AHRS?
How much better is the 5000 series?
Any input would be appreciated!
What kind of airplane?
For me, having an RV-8 it was not only an easy upgrade, but the only choice I had or it would have been a major job.
The 5400 needs you to add either an AHRS or ADAHRS since the 4500 has it internally and the 5000 does not.
Again, I had no space for the ADARHS, so I replaced my 4500 magnatometer with the “RED BOX AHRS”.
If you have the space, go big! I have all the options of the bigger 5000 series, but less buttons.
It?s an Rv-10 and I do have the external AHRS in the rear bulkhead
Sounds like the 5400 makes most sense.
Do you think Dynon will discontinue all things AFS?
Good question.
I think it may take some time before they do. It seems that Rob is still very involved and will hang around for a while.
We've all been hearing this question for a ong time now (3-4 years?), and yet Rob and team keep putting out new features and new panels. You are most familiar with the operation of the AFS units. The 5400 is a great upgrade for you.
Vic
The biggest difference is the buttons and knobs. It will flatten out the menus a bit more than on the 4500.
The upgrade from an electrical point of view is identical. The larger screens will require new panel cut outs. If you have the room, I would go with the larger screens.
If not, the 5400s work just fine.
I did
I upgraded my 4500 to 5400 touch last winter. been flying all year with the new screen. Man what a great upgrade. Youll be amazed at how much has changed in the 5 years since I bought the 4500. The thing I like best is the comfort and safety that I feel with the integration with the ARINC. It just works better, maybe its the faster processor I don't know, but its confidence building.
I added the 3 knob accessory panel above the screen giving functionality knobs that the 5400 doesn't have due to screen size.
yes you need a new ADHRS, but its worth the effort, I think
