R rwayne Well Known Member Dec 9, 2020 #1 I am upgrading my 4500 to a 5400T with the new EMS engine module. Will I need to change any of my original engine sensors?
SmilingJack Well Known Member Dec 9, 2020 #2 Oil pressure and Fuel Pressure sensors need to be the Kavlico Sensors.
R rwayne Well Known Member Dec 9, 2020 #3 rpm sensor Thanks! That helps a lot. Does the rpm sensor wiring need more that just moving pin position?
T tomww Active Member Dec 10, 2020 #5 I had to move some pins. And the two sensors mentioned. I did 3500 engine sensor version to 5600 plus new sensor module
