roadrunner20
I was running my AFP fuel pump to begin to purge & calibrate my fuel tank.
My max fuel pressure is reading 4.0 and I'm pumping only a small trickle. I'm about to do the timing test for gph. I guess when you figure the flow in gph, it may be correct. It just seems real slow to me. I was expecting a greater flow than that.
What is everyone else seeing here?
