Here's my 2c worth:
- RVs are great fun for Aerobatics, -8 especially with the tandem / better vis.
- As above, they are easy to get wrong however, due low drag / low VA, and RV-8(A) due variable CG.
- You need to watch Aerobatic Weight 2 up in the 7/8, and effectively cannot do them in 4/6 2 up (legally).
- RV-8 (and I presume 8A?) you cannot do manoeuvres requiring full / hard rudder from the rear seat - you'll bend the rear rudder pedal rods / cannot get full rudder.
- Control forces are light, which is "great" for the experienced / more skillful pilot. They are not for the novice / agricultural / ham-fisted pilot, who will easily pull the wings off an RV.
- NB best practice during aerobatics is to wear parachutes. Getting out of the rear seat, if required, is an unanswered question. Training is one of those areas where best practice should ideally be followed.
- Learning from scratch needs a proper laid out syllabus covering stalling, Max Rate Turns, Spinning (Full & Incipient), Unusual Position Recoveries (Nose Hi/Lo/Ballistic) as well as the "Basic" Manoeuvres.
The RVs are weak in some of those basic areas - I would much rather teach some of these in an aircraft where the student can learn / explore / get it somewhat wrong, than an RV where a "nose low UP" is a serious problem requiring correct and immediate action, and I'd be wary of teaching / practicing Ballistic recoveries. In addition, the RV "buffet margin" is poor / narrow (in fact the RV-8 is the best due the gear leg/wing buffet, I suspect better than the 8A as well), so hard to get a feel for the buffet. And of course, please ensure there is a CB easily pulled to kill any nagging stall warner
We designed our RV-8 so you could do aerobatics from the back - it essentially requires that the rear seater can see clearly (preferably analogue) 'g' / ASI / Altimeter from the back, without having to peer round the front seater too much.
I do/have done a lot of teaching aerobatics (RAF - Jet Provost), post RAF in Bulldogs, Fireflies, Extras, JPs, RVs of course, and as Paul says, for someone who has never done any aerobatics, I'd recommend doing a proper intro course on a more appropriate type. It would then be quick to convert that knowledge to the RV in 1 or 2 flights.
In the UK, each RV needs a Spin/Aerobatics Test Flight Schedule with an appropriately approved pilot (1 flight usually suffices although many do 2 in the RV-8, first solo, then dual) before being cleared. Link here
Schedule - might be worth a review, and include in Section 5 the rear seat(er) if you intend to give/receive instruction in an RV-8(A).
Andy
RV-8 G-HILZ
RV-8tors
