If you read IAC forums, a number of people through the years have suggested creating an aerobatic category for RV aircraft.
By creating an RV category they hope to increase participation in their events and broaden their membership, while also creating safe events tailored to the capabilities and limitations of the RV series. RVs would compete against other RVs.
They've been discussing this for years, not sure why they haven't just done it.
Lots of reasons. First, when you start talking about a category just for RVs, you're talking about a "one design" category. Yes, as mentioned above, it's a logistical challenge to fit extra categories into the 5 that are already flown. But there are other issues.
One problem with a single "one design" category for an RV is that you have an airplane that is capable of primary to intermediate level aerobatics, and with only one category, what level of difficulty do you make it? An RV category could be similar to Primary, Sportsman, or Intermediate levels of difficulty. Unless there were separate "one design" RV categories for different skill levels, it would either exclude lots of RV pilots (who are at the beginner level), or be boring for others who have more advanced aerobatic skills.
Another reason this has not been done is that RVs are perfectly capable of flying the current Primary and Sportsman sequences, even without inverted systems, if you don't mind (and monitor) your oil loss. There is also the spin issue. Some folks are uncomfortable spinning their RV. Some say that an RV sequence should not have a spin. Yes, the small-tail RV-6 models take longer than normal to recover once fully-developed, but RVs have no spin quirks, and competition spins do not get into the fully-developed range. IMO, experience, comfort, and competence with spin recovery is a fundamental requirement for doing safe aerobatics. If you are uncomfortable or unable to recover a spin in your airplane, it would not be an unreasonable position that you might be better off avoiding the full range of basic aerobatic maneuvers altogether.
"RV-friendly" really means lack of negative G exposure. Regarding judging criteria, how do you apply precision judging criteria to what is essentially barrel rolling when any rolling component is done under positive G? Right or wong, many would feel this would compromise one of the most fundamental skills and foundations for aerobatics - the ability to precisely roll the airplane without deviating from altitude or attitude and heading.
There's also the show of interest issue, given that there are over 7,000 RV's now flying, and only about 3 per year compete across the country. And this is not due to any barriers to entry. Bottom line, you have to be a "self starter" to find your way into this sport. If you really want to do it, you'll use what you have...or modify it if you really need/want inverted systems.
With all that being said, if redesigning the IAC contest structure slightly would truly bring in significant numbers into the sport, then I'd be all for it. I'm just not sure that it really would at this point. I really don't think
significant RV participation hinges on the inverted system issue. Folks compete just fine without them in the Primary and Sportsman categories. I recently looked up the percentage of all U.S.-registered inverted-system Citabrias that participated in competition acro last year. Most Citabrias don't have inverted systems, but the 7KCAB does. Of these, only 2.3% competed (6 of 266 registered). Considering the 7KCAB is well-capable of winning the current Primary and Sportsman categories, I just don't feel there would be more than a handful of non-inverted system Citabria pilots across the country who would participate only because new sequences/categories were created for non-inverted system types. I feel the same way about RVs.
So for any who are interested, don't wait for someone to make it easier for you. If you are not a self-starter, and do not have a high level of confidence in your skills, then it might be that competition acro is not for you. Or maybe it is, but you don't know it yet due to lack of training. There is something in aviation for everyone.
