sinflrobot
Member
My Aera 660 is behaving erratically. The symptoms are:
1.) It has been failing to power up when connected to power.
2.) Battery tends to end up in a discharged state.
3.) Sometimes removing the battery then connecting in the cradle will get it to start up. (then you can add the battery back in and charge it up)
When it is working, the unit is great, but not being able to reliably get it powered up is becoming a major pain.
I tried updating to the latest firmware but that doesn't appear to have helped.
Any one else experienced this behavior?
