Tbone Well Known Member Oct 26, 2018 #1 Can someone help me with the schematic on how to make these two units work together? My issue is what to do with pin 17 on TT...
A andyrv Well Known Member Oct 26, 2018 #2 Serial Data Terry, You will need TX1 Data Out (blue wire) or TX2 Data out (orange wire) from the Aera 660 wiring harness connected to pin 17. Both units will probably need to be connected to a common ground point as well. Andy
Tbone Well Known Member Oct 29, 2018 #3 Thanks Andy! So basically just one wire to 660 will allow Digiflight to follow GPS track? Too easy!
