Hi
I came across my first bad rivets and I had to drill them out. As many may had done I slightly enlarged two holes in the process. Those rivets are flush head size 4-7 and they are the ones attaching the Vertical Stab aft spar VS-803 to the spar doubler VS-808 to the hinges bracket VS-410PP
What do you suggest should I do?
1) Use same size rivets assuming the small gap will be filled be the rivets and that the rivets lines along the spar will ensure that the spar and the doubler are in one piece and the remaining four rivets will bear the load on the hinges?
2) Replace the hinge bracket with a new one so the shop head will have enough material to hold on.
3) Enlarge the holes to the next size and use larger rivets though I am not sure if I can meet the minimum edge distance requirement.
