MrNomad
Given that this is our second RV building project and we’re talking about a third, I decided to experiment and figure out which method of filling pinholes gets the fiberglass sections of the airplane ready for paint with the least effort and lowest cost.
Method 1: According to Van’s, mix 1 part WEST to 1 part Acetone. Squeegee it on, sand it smooth. After 2 coats of $200 per gallon primer (good stuff), it was ready for paint.
Method 2: Using $200 per gallon primer, give the piece 2 coats, and squeegee the second coat. This method filled the pinholes but the primer will require sanding and (given that I am a perfectionist) it will need another coat of primer.
Method 3: Using $200 per gallon primer, give the piece 2 coats. This method left many pinholes. The fiberglass piece will need more work and another coat of primer.
Method 1 was the least expensive, and most productive. Sanding WEST is more difficult that sanding primer, but you get to paint status fastest via Method 1.
Your results may differ. No flaming please!
